Throttle cable
Kegan B
IN
I was running an edelbrock and my stock throttle set up bolted right on and worked ('74 Scamp 318 2bbl car). I went to a QuickFuel 600cfm and nothing will reach, I was wondering what everyone else done to solve the issue? I buddy said to go to a lokar set up but can't find one for a SB.
I have an Mancini adjustable throttle bracket that raises the cable higher on my 340, M1 Intake with a 1" carb spacer underneath a Holley 650 DP, I'm running a stock 73 cable from my old 73 Duster. 318 2bbl car....it's in an early-a now so maybe that's why it reaches better?
No idea, I have an earlier kick down that adjusts since mine wouldnt reach quite right. May have to try and find a decent throttle bracket
Can you use a universal style throttle cable, and cut it to length? or does this have a mechanical linkage that now doesn't fit?
http://paceperformance.com/i-6059936-lokar-universal-throttle-cable-kit-tc-1000u.html
or if you're on a super budget...you can cross your fingers with the mrg..lol
http://paceperformance.com/i-6102305-mr-gasket-steel-braided-throttle-cable-kit-5657.html
and/or this guy...to support the throttle cable and kickdown cable right on the carb base.
http://paceperformance.com/i-610932...t-aluminum-throttle-cable-bracket-20-112.html
