I'm tired of using the search feature that doesn't work. What's everybody using for a throttle cable on the early A with the V8 pedal assembly with either the Super Six conversion or 4 barrel?
Thanks.
Thanks.
I get a **** ton of threads to look through. Search Results for Query: v8 throttle cable | For A Bodies Only Mopar Forum
I typed in "Slant 6 throttle cable" and there's some stuff you may be interested in. Hope it helpsI'm tired of using the search feature that doesn't work. What's everybody using for a throttle cable on the early A with the V8 pedal assembly with either the Super Six conversion or 4 barrel?
Thanks.
I'm pretty sure I'm using a 340 cable on my 4-barrel slant. But it's been a long time since I did the conversion and my memory has betrayed me before. I can go out to my garage and measure the length of the cable from firewall to carb if that would help.I'm tired of using the search feature that doesn't work. What's everybody using for a throttle cable on the early A with the V8 pedal assembly with either the Super Six conversion or 4 barrel?
Thanks.
OK, went out to check. Not easy to measure a curved cable with a metal tape, but my 63 Valiant slant six cable appears to be the same length as the cable in my 67 Barracuda 360 - roughly 17 inches from firewall to the carb attachment. The cable in my 65 Barracuda (340) is only 15 inches. I don't think a shorter cable would work on my slant six. Different year, different linkage, who knows?
