throughly confused....
deviledchin
Sellersville,Pa
Hi to all, I have a 71' demon 4spd build date 4-71 and the motor 1-71. What exhaust manifolds orignally would have come on this.
I see 3418623 and 3418621 as a pair, also 2863549 and 2863553 (Hi-po?) as a pair along with other combos?
Were the high performance ones available for this car and how would you know? Any codes?
The car has 25k on it and I would like to keep it as stock as possible.
The original owner swapped out the carb, intake and exhaust.
PLEASE help, way too many numbers......
THANKS in advance.
Sorry for the fat fingers in the title. I have noticed several sets with 3418623 and 2863553. Is this a possible match?
The 3148623 may be correct for a pass side 71'. I'm getting more confused the more i researched....lol. Hopefully a member with a matching number car will chime in. Once the numbers are determined, finding a set may be a even bigger hurdle. Good Luck in your search.
