Time crunch & no spark :(
The gap is about .035-.04. How would I adjust it?
Checking with a brass feeler gauge I hope, if not you can damage the pickup.
There is a screw to loosen and it will slide. If you look you will see a hole shaped sorta like a v, use a screwdriver in there to move it.
.008 should be what you want.
BINGO! It was that gap. Thank you guys for all the help. I'm shipping out this week so I really appreciate it.
It's still got a few issues but it's running. Pretty sure my rear main seal is screwed up somehow because it's gushing oil when it gets to temp. That and the trans pan gasket won't stop leaking. I've swapped it out twice yet I can't stop it. I'll replace the rear main seal and use a rubber gasket for the trans pan when I get back in Sep. Looks like Infineon will be all you this summer Bad440. Hopefully I'll see you there in the fall.
