PhillH
Well the time is here, everything is just about back in order on my 71 Scamp auto that I rebuilt my first engine for, think I've got most of the bugs worked out so now for the ignition. I've been doing some reading/searching and I think what I would like is the MSD Streetfire box and coil.
So what it came with is a factory 318, points distributor, a 2 wire ignition box, and a ballast that has 2 terminals but 2 wires on each side, not the four terminal one, four wires into two terminals.
What I would like is to do away with the ballast and box completely, go all modern. So I would need to know what distributor I would need to go with the MSD box and coil, and what to do with the existing wires? Also I don't know what to do with the alternator as the one I have isn't charging, so what to replace with? I am planning on doing a whole car wire kit, electric fans, fuel injection, so keeping that in mind, I want to be able to use these parts now and after the rewire, driving car while working on it.
What do you think????
