Timing chain advice
So I can just use a non vvt timing set. I didn't know if that was possible even with locking it out.
OK I'm going to ask
Why would you want to lock out the VVT?
All the highest performance production engines on the planet use some form of variable valve timing, it is a very sound engineering practice.
I would be looking for a way keep it.
OK I'm going to ask
No doubt it's great technology but I'm running a carburetor no efi. The vvt can become an issue when large cams are used. Most either lock it fully of partially so there isn't piston to valve clearance issues
Precisely.
