Timing cover pitting.
Actually, now I'm confused. Some searching is telling me I should have the metal shim and bolted on passenger side for timing marks.
Mines actually casted into the aluminum on the passenger side, driver pump inlet.
Cover must be removed to replace crank seal.
I don't see covers like mine, they're all driver side indexed. I wasn't looking forward to spending money on a balancer tailored for a different cover
Passenger side timing marks. Seems rare.
1969 only
just remark your balancer to coincide with the new cover marks, pretty easy.
or buy a new balancer for $100 (yours is probably pooched anyway)
1969 only
If it comes loose I'll just try and center it and weld it together. Did that on a Chevy tracker 4 banger. I used welding rod stubs for equal shims all around center.
Redline it often @ 6500.
You need corrosion inhibitor. It............stops corrosion. If you in a climate where the block can freeze, then you CI + anti freeze.
