Hilderbrand1983
I'm sure the answer is pretty self-evident, but I want to make absolutely certain ...
I removed the old, cracked, round, rubber seal in my timing chain cover. It is inset into a ring in the timing chain cover itself. I'm shopping for a replacement part, but I'm not entirely sure of the part's "name." Is it the "timing cover seal"?
Also, I see that there are "front" and "rear" oil seals for the crankshaft. I have a new rear main seal, but I don't remember removing a "front" oil seal from the crank ... that is, unless the front oil seal and the timing cover seal are the same thing. Are they?
Let me know if you need more information. Thanks, ahead of time, for your help!
