U can’t leave all that sealer in there. It will eventually come off and go thru the motor. Kim
use a razor blade to clean all that out. it's a timing cover, not a bagel
That’s some funny ****.View attachment 1715632348
use a razor blade to clean all that out. it's a timing cover, not a bagel![]()
I don't like leaks lolView attachment 1715632348
Seems like everyone i have is late model lol. I have tore down a few 318s all from the 80s that's where most of my parts have came from. Had I known there was a difference i probably would have used the earlier one im not a big fan of how easy that thing pressed in. Don't seem very tight to me. I may go back and clean the other one and paint it and use it instead. I think its the original one to this 360.Yeah, evidently I've not seen one that late a model.
I agree, but not that it will "go through the motor". It actually won't go through the motor. It will come off and get sucked up into the screen on the sump choking off the oil flow to the oil pump.U can’t leave all that sealer in there. It will eventually come off and go thru the motor. Kim
Thanks guys I never even thought of that. I will scrape it out of the inside.I agree, but not that it will "go through the motor". It actually won't go through the motor. It will come off and get sucked up into the screen on the sump choking off the oil flow to the oil pump.
