VC was disconnected while checking the timingWas the vac adv hooked up while you were checking timing? Should be disconnected & plugged.
It seems to run ok, but I can feel it surge a little. I jetted up some but that did not resolve it. New engine so I'm just starting to work on the tuning.Does it take throttle, and rev ok?
I had one case in which like yours the timing jumped, and I mean it was here and then there, with no transitions of in-betweeness. In my case, the engine did Not like to rev up, and the jumping strobe got worse and worse.
I found the problem in the reverse connected pick-up coil. IDK how that works exactly, but after I reversed the polarity, I had to reset the timing cuz it was quite different. After that is was normal.
Yes, solid rollerAre you running a roller cam? Those bronze gears are for billet steel roller cams.
