Claudius
I am forced to replace the timing chain cover for my 1968 318 engine due to corrosion of the water jacket holes in/out of the water pump assembly. There are no indicators on the front of the cover plate for use with setting timing when I start up the engine again.
The problem I am facing is that I do not know whether a replacement timing cover should have the marks on the driver or passenger side of the cover plate. :read2:
I found items on eBay that are in good condition (because the supplier provided me with additional pictures) but I have the choice of where the timing marks are located. The postings suggest driver side for 71 & up and passenger side for 1968-1969.
Newer harmonic balancers have timing marks already engraved for use with the timing lights but I would like to be correct for the 1968 model year.
Can anybody shed some light on this topic?
