Mopar Tim FABO Gold Member FABO Gold Member Joined Nov 29, 2014 Messages 29,577 Reaction score 29,794 Location vista CA. Rating - 100% 13 0 0 Jan 4, 2021 #1 Contact seller Need early small block timing tab. Bolts on the right side of timing cover.. Thanks
MoparMike1974 FABO Gold Member FABO Gold Member Joined Jun 16, 2017 Messages 4,573 Reaction score 4,372 Location Maryland Rating - 100% 17 0 0 Jan 4, 2021 #2 I have one off a poly. Shoot me your address if it will work for you.
Mopar Tim FABO Gold Member FABO Gold Member Joined Nov 29, 2014 Messages 29,577 Reaction score 29,794 Location vista CA. Rating - 100% 13 0 0 Jan 5, 2021 #3 MoparMike1974 said: I have one off a poly. Shoot me your address if it will work for you. Click to expand... Same? Not sure......Let me check.......
cudamark Well-Known Member Joined Mar 14, 2009 Messages 11,811 Reaction score 3,470 Location San Diego Rating - 100% 20 0 0 Jan 5, 2021 #4 There are at least 3 different ones. Do you have a photo of the one you want, or, know the exact application?
C chignikred Well-Known Member Joined Apr 12, 2009 Messages 647 Reaction score 150 Location WA Rating - 100% 9 0 0 Jan 5, 2021 #5 62 poly 318 tab is 5 degrees different than a 66 LA
