earthmover
in the tire smoke
well got to go to the local test and tune last night car ran preety good ...off the trailer the car ran a 7.65 with a 1.65 60' .. tire are really bad one want keep air very long i put 15psi and when I get back to the truck its down to 10/13 had 10 on 1 run man this thing was something to drive then..anyway made 4 pass and only tune was move the timing and it went 7.63 with a 1.65 60' my freind said it jacked the driver wheel up on the dry hop all in all had a great time no problems except tire and trying to learn to drive this thing again......temp got down to 37 last night so not the best cond. dew was on the track...plan to go over the valves again ,try 1'' spacer,also going to take the shims out of the rear it has 2in each side 6 total on each side and unclamp the back of the springs...I'll post the slips later if i can ...oh had a bad time with batt. as well had to jump the car 3 times out of the 4 runs gotta get a new batt. but its more init with some tune I think and shims out.....:cheers:
