TNT last night
no didnt make it friday..plan to try this fri. they said it will be open sat as well for last run of the year...
hay bob the track will be open friday from 11 to 4 called them today also will be open sat. same time ..i plan to try friday and see what goes on with the changes i made to it.....turned the press. up on the pump today was running out of fuel before top end i think bustting up just a little until i got out of the gas......it was on 5psi now i have it on 7.5 didnt get to try it but hope that was the problem.......plan to turn the timing up some at the track what do you guys think about 31 shooters should they be uped or am i in line.....:cheers:thanks for the help guys...
hay bob thanks for the info wish you could be there...as for the stumble i dont have any so i guess im where I need to be.....thanks have a great holiday......
