FABO'ers:
I'm starting a 340/416 build with '72 340 block; Eagle forged crank; Eagle I-beam rods and dish Ross pistons. Along with aluminum Edelbrock heads. With this piston I will need to deck the block 0.017" to get zero deck and take advantage of the closed-chamber heads; as well as machining the heads to reduce the combustion chamber volume to get my desired compression ratio.
I've read everything I can find about quench but haven't seen this addressed without custom pistons.
So, should I cut the block to achieve zero deck; and my quench distance will be about 0.040" (head gasket thickness)?
Thanks!
Thanks!
