I want to put 70 dart on toggle and push button start I am not a wiring guy I know yellow is starter wire and im not using ballast resistor which is brown wire? would like to use relays also
Just wanted something different I don't use ballast, ignition is stock, dist has petronix electric conversion . I will still have key switch to keep steering lock but I like the idea of hiding a start button and kill switch.
