71DodgeDemon340
Just waiting on my 5 blade fan to arrive tommorow, gotta do some mock up to see what depth clutch im going to use. Then i figured might as well order the milodon water pump and t stat with the fan clutch
I thought permatex #2 would be a good choice
Thats what i was thinking, i can only hope that i can change it out without disturbing the seal on the timing cover. I know if i loosen the bracket to adjust the power steering belt it will weap a little coolant from between the water pump and timing cover but seals back up after you tighten it
Im hoping that it only being on there for 4-5 years will aid in removal
