64 SRT8 Dart
Hey everyone, got a lot of questions (some might be stupid) regarding rebuilding the front end on my 66 Valiant and then some....hope this is the right section for all this?? I'm also gonna go ahead and switch to the BBP discs I got off a 76 Dart last fall. I have the spindles, rotors, calipers and caliper brackets. Also, gonna swap to manual steering from a box out of a 64 Dart /6.
I plan on ordering the tubular uca's from RMS. Also, gonna try and get a set of the tubular lowers from Badart.
Now with all that being said...will my factory strut rods work with the tubulars from Badart? What would be the best front shock/coil-over to work with this combo?...knowing I'm gonna have to brace the shock tower.
I'm gonna order my front-end kit from P-S-T but have some questions with that. When ordering my kit, do I tell them I need a pitman arm for manual steering out of a 64 Dart or will it be the same as if it were in my Valiant or does it matter? Will the 66 Valiant outer tie rod ends work with the 76 Dart spindles? Is the lower ball joint the same between the two years? I've never ordered anything from P-S-T, are they pretty knowledgable on this stuff and won't send me the wrong stuff when I tell them what I need? I'm kind of stressing a little bit about it because I don't want to get the wrong stuff to only get into the middle of the build and it be the wrong stuff....this is my daily driver, so all of this will have to get done on a weekend.
What's a good master cylinder to run (manual) for my year of car with disc/drums that will work with the factory plunger rod??
About the car... a stock 273 Valiant 2dr w/904 and full interior that's daily driven.
It's weight is stock as well....never weighed it so.....
Eventually the car is going to end up as more of a Pro-Street/touring type car so wanting to do upgrades while I'm having to fix stuff.
Everone's help and advice for a "suspension noob" is very much appreciated!!
