Nokke
Active Member
I Have question for you guys what should i choose for a camshaft to reach 600 hp?? or do you think its even possible with a new camshaft??
My combo is now
408 stroker La block
Eagle 4340 crank
Eagle H-rods
Srp 10.5 pistons
Indy cylinder heads 210cc 2.10/1.65 valves ported & polished
the heads flows at 650 lift 307/230
carb 1050 dominator
manifold indy matchported to the heads
Camshaft comp cams xr286r 0.50 duration 248/254 576/582 lift 110 lob sep
td machine rockers 1.6
tti 1 5/8 to 1 3/4 stepheaders
engine driven and tested in bench to 555,3 at 6300 rpm & 527,8 ft at 4900 rpm
My combo is now
Eagle 4340 crank
Eagle H-rods
Srp 10.5 pistons
carb 1050 dominator
