440DART1970
1970 Dart 446ci Swinger
Are these products and psrts any good from TSP??
LOL! I'd like to know howIf you need instructions for a "ready to run" part, it ain't ready to run
To screw with this type of unit since I have allways used a MP or stock unit. This one is different for sure.
I'd like to be able to change the curves, rate and limits.
I don't know if they are as screwable as the stockersame areLOL! I'd like to know how
rather tite convertor there ! LOL1978 RV 440 motor. +30 0ver = 446ci 10.35.to1 fordged TRW Speed Pro pistons, Steel crank internally balanced. Comp cams .488 ,491 lift - Duration @.006 274, 286. 915 heads slightly cleaned up ports, upgraded vale train & Springs, Johnson BB lifters, Aluminum water pump housing and water pump, Speed Pro Harmonic balancer, Holley Street Dominator intake, Quickfuel SS-750 mechanical DP, MSD 6AL, MSD 8546 race distributer and coil, Schumacker Ceramic coated Tri-Y header, Motor mounts and Torque arm.
727 trans, hughes 200 stall converter, Cheetha manual/auto valve body, lokar kickdown cables, 8 3/4 abody rear, sure grip 3.23 gears for the street and cruising
