bobscuda67
I have two small block torque converters for sale.
The green one is a stock stall unit that fit 67 and earlier 904's with a neutral balance. I bought it as a rebuilt unit and put about 3000 miles on it. It worked perfectly as you would expect from a stock converter. Asking $30.00 for it.
The black one is an ACC Boss Hog unit. Part number 53022. It is made for a neutral balance 904 fitting 68 and up transmissions. I would consider this as a stock stall unit too. The part number is painted on it if you want to look up the specs on it. Asking $40.00 for this one.
They both ship from 48182.
