I don't see a value anywhere for rubber, but if I remember right the factory gasket value is 12-13 inch lbs. (but that is for cork)
You could start there and if you have the rubber/steel gasket tighten a little more if it looks like it wants to leak.
Trailbeast, I think you meant foot pounds of torque. The manual calls for 150 inch pounds.
well said Fishy68 I was referring to the hard rubber gasket that they ship with pans, at least thats what was in the deep pan kit I bought for my 904 a couple of months ago , it didn't have a steel core just hard rubber and was garbage even after straightening the pan it was seeping , put the cork back on and presto dry as a bone .
