rod7515
Before I paint the engine compartment I wanted to fit everything together so if any modifications were needed I wouldnt have to redo newly painted areas. For the most part things fit fairly well. I have 2 questions tonight, first is, are the torsion bars the same front to back and left to right. 2nd is, on the lower control arm, the stud that goes thru the K Frame is tightened down with a washer and nut. I cant find them for one side so where can I find them to buy?
Thanks
Rod
Thanks
Rod
