joshua dewitt
Heh, tech tip here. Sincemy cucpention all poly... Found some torsion bar poly to match.. Problem, poly not flexable to slip over end of torsion bar. Git creative, used one of the wifes cooking bowls, put bushing in bowl with water, heated on hugh for about 10 mins. Watched the whole time, they stared to bubble, the stared spinng in water, said ok lets try this, using a oven mit they pushed over the hex end of the bar and after slipin over, the hole srunnk back to the orignial size to the torsion bar when it cooled... Wored out awsome!!! Now just need to assemble front suspention. Just hought i would pass this tip.
