It’s sucks don’t it? Limited choices suck. At least the intakes available are pretty good. Chink knock off, rpm, M1’s if you can find them and Indy has something.I'm running a BPE 408 so the RPM Airgap is a bit special with the use of the magnum style attaching bolts. Can't just swap manifolds, unfortunately.
