[Found!] Trailer Hitch
Mopar69gts
Mesa az
I'm looking for a Trailer Hitch for my
69 Dart.
Anyone have one?
I've talked with some local Shops about making a Custom one but I'm just seeing
What may be out there first...
Thank you, Mike
If you're a welder or you know one, there should be a plan in your Owner Manual.
This came on my Dart when purchased in 1973
So it looks like it bolts to the bumper
And floor pan?
Was it bolted outside or inside the
Bumper?
What year is the Dart it came off of?
Sorry for all the questions just making sure that would work.
I have a 18' flat bottom race boat
I want to tow, it only has about 100 lbs
Tongue weight, and weighs 2000 lbs
Thank you
That should work!
I see that it says 1000 lbs load
The boat I want to tow is about 1800
But even if I need to beef it up a bit somehow
Still not too big a deal.
How much do want for it?
$25. Plus shipping. This thing is heavy, close to 60 pounds. I can give you some measurements to have one made. It should pull more than that.
Ok sounds good to me
If you could check on shipping I'd appreciate it.
Thank you for offering to send dimensions
Just don't really have the time to fab one up
Also I like that this one was on a Dart already and know it will fit.
Thank you!
