Got the Dougs hung on the engine, good fitting headers! Since the stock cooler lines no longer fit, where do you guys route the lines. I'm bending 5/16th hard line from the 727 up to the bottom of the rad. I can run them up the frame rail then across, or tuck them over the header tube and run up the oil pan flange. This is the first time trying this, just wondering what works? :dontknow:
