For people out there that do use their torque wrenches, spec is 150 in.lbs.
That stuff works good, until you have to remove that stuff. I call it Gorilla Snot!Use 3m weather strip adhesive between pan and gasket when you put back together.
Yes, just a thin bead, takes a razor to get it off. Seals a trans pan gasket great though.That stuff works good, until you have to remove that stuff. I call it Gorilla Snot!
Oh your absolutely right, it does seal great.Yes, just a thin bead, takes a razor to get it off. Seals a trans pan gasket great though.
