no1newb
Ok, so I decided to drain my tranny and put new tranny fluid in it, I got 3 quarts of 80w-90 and put it in there, i also put Teflon on the drain plug. well, now i realized i shouldn't use valvaline 80w-90 because its Gr-5 and ive read a couple places that i should use gr-4 and i saw people were using synchromesh, so i went and got 4 quarts of that today, and i couldn't get the damn drain plug off. it kept striping the corners of the square plug..why did they even use those nut heads? and will it hurt having a little less than 3 quarts of 80w-90 and the rest pensoil synchromesh?
