GTS NOSE CONE
Im back last time i posted i was having a problem that my 4 speed linkage was locking up on me. I dropped the linkage rods off the bottom of the shifter put the 1/4 rod threw the bottom to neutral it out and adjusted the rods. Well i was driving the car today and it locked up. i couldnt get it into any gear but reverse. I was lucky that it stayed in a high gear to get it home. I had the wife try to shift the shifter and i got under it and it looks like the shifter is trying to get 2 gears at once bot rods are moving. 1.2 ans 3,4. My question is that a shifter problem or is it a tranny problem. Sometimes its fine but the shifter seems very sloppy all the time.
