rod7515
Was wondering how many are using a trans cooler. What brand it is and how do you have it plumbed in.
Thanks
Rod
Thanks
Rod
Can I ask what temp your trans runs at?
Thanks
Rod
ir, how and where do you have it mounted?
I would like to have one but don't have enough room between the radiator, a/c condenser and grill on my '72 Duster.
C
Besides the one in the radiator I run one in front of the radiator but not touching it and also a cooling transmission pan
treblig, whats on the other side with the fan on it?
This type of pan is not really worth the money charged for them. It picks up hot air off the pavement, and with the hot air going through the tubes, little if any cooling of the oil results.
Best transmission cooler on the market is made by Long Manufacturing, it is the stacked aluminium style. While it is sold under many names (B&M, TRU-COOL and others) it is still made by Long.
Nice system you have worked out there Treblig.
I got mine at a scrap yard out of a mid 90's Dodge van with HD Towing package.
Quick zipped it in. Ran it in line with the lines going to the radiator from the tranny. Works flawlessly. Tranny cooler is one of the simplest mods there are. Most logical too
