Trans crossmember 63-66 A body?
dart4forte
Mesa, AZ
Anyone have a picture of the modified trans crossmember allowing for duel exhaust on a 63-66 A body?
I don't think you need to use that, if your exhaust
installer can bend pipes halfway decent.
I have dual exhaust 2.25" under the tranny crossmember.
I don't hear any "hard times" with normal sized speed bumps.
I am not hitting on one nearby speedbump, that I did when I had my
67 Camaro; the headers hit the ground with that.
I am using 205/70/r 14 tires, whcih are the same height as my
stock 7.00x 13 spare tire.
The V8 Valiants came with 7.00x13. 1964 and newer.
This is what I did on my 65 Cuda. With 2.5 inch exhaust it did bottom out on speed bumps, but my car sits low.
:thumblef:
Here is what I did. First pic is the trans mount, second is of hte frame of the car.
