[SOLD] Trans-Dapt Wheel Adapters SBP to BBP
74DartSwinger360
The Brat Pack
Valrico, Florida
Fellow members of FABO,
I have for sale a set of Trans-Dapt Wheel Adapters SBP 5x4" to BBP 5x4.5"
These allow you to keep your stock SBP brakes but give the wheel choices of BBP
I used these just to keep a project rolling till I found some Yukon axles.
I know these were run on a slant 6 74 duster by the previous owner.
I have inspected them and can find no cracks or damage (just some orange paint from previous owner painting aforementioned duster) and none of the threads are striped or boogered up
I am including 5 of the 7/16" LH and 5 of the 7/16" RH lug nuts and 10 of the 1/2" for the shown studs
Parts are located in Valrico, FL 33594
I'll let the lugs and adapters go for $45 shipped
(Post or PM if interested)
Thanks,
Emilio
when these are mounted to a stock axle, will the SBP axle studs stick out, or are these thick enough so that the LBP mounting surface is flush ?
(not necessary looking to buy, but something I always wondered and might be of interested to prospective buyers)
Good question should have put it in the ad.
They are 1 inch thick so the axle studs do not stick out from the spacer.
They are of no interference to the wheel mounting surface.
