Trans fluid
DartGT55
USA
What kind of trans fluid do you put in a 727 small bolt trans and not knowing what’s in there now can you mix 2 different fluids per say synthetic vs dexronmercron
I would drain as much out as I could and go back with Dexron 3.
OR if you trust the shops have them do a fluid swap (dropping the pan and filter would be wise) but they can swap out whatever is in there with fresh fluid without dropping the pan
