Can anyone me what year trans this is ? And how, which #s tell you the year.
Thanks AL
Thanks AL
How do you translate the numbers to the year? Or do you have the check a chart somewhere?2801542 shows as a 1967 trans for a 318.
I used the chart that's on MyMopar.How do you translate the numbers to the year? Or do you have the check a chart somewhere?
The difference is in the spline count on the input. 19 on the early models 24 on the later.Changed in 67. This is on BB. SB used a smaller convertor register on the early models. I think 66 or 67 was the split66s and older, IIRC, have a different front end and won't accept 67 up convertors; jus saying
I think on SB 727s also, in Canada at least, with 67 the first year of the 24? I only ever built but one 66.The difference is in the spline count on the input. 19 on the early models 24 on the later.Changed in 67. This is on BB. SB used a smaller convertor register on the early models. I think 66 or 67 was the split
