I have an 85 D150 with a Slant and a 727. (YES I know the difference between 904 and 727)
How much power does a 727 consume? vs a 904 (OK, 998,999, or whatever variant of the lighter duty trans that you might come across) how bout vs a stick like a 833OD or maybe even a T5?
Does stall speed in the converter play a part there?
Is the power consumption of the trans a percentage of engine output? cuz I can't see a given trans behind a 500 hp big block taking up the same percentage of overall power as it would in my slant..... Im thinking there is a "set amount" of power needed, to spin the converter full of fluid, also to turn the pump pushing "X" number of PSI of fluid pressure, spin each of the interior drums, shafts, etc that would be the same regardless of what is in front of it....
(pulling numbers out of the air for a moment here) that if it takes say 40hp to "run" the trans in a big block, that it will take the same 40hp to run the trans behind my /6....
not talking aerodynamics, rear gear, tire size, etc here. just the power to run the trans.
