dare_dude
Active Member
Anybody using A&A Tranny blanket? I see they offer a long and short version?
I agree with the aftermarket front drum ! Had a 383 nitrous Motor in a 67 Valiant and the transmission got weird on me shifting funky and slipping . Long story short the front drum was cracked on the back side all the way around with maybe 1-2" holding it together .No stock front drums for me anymore . Luckily I dodged that Bullet . There's stubborn people out there that wont upgrade them. It's just a matter of time until a rude awakening .ont drum a I’m shocked to see that as well. However, technology and new upgraded parts I’m sure have evolved that like many other things.
For what it’s worth, not that I would recommend it or anyone else would recommend, but I know people who have ran 9s and 10s for many of years with nothing more than a stock front drum, cheetah RMVB, and bolt in 12 element sprag. But I would certainly be upgrading that drum in the future.
Do those work in the outside world. Getting tired of the wokie tokie stoopidity going on. How do you refer to your car now; he, she, it, shim or as a friends ex referred to his truck project, that expensive heap of rust in the garage?Can anyone recommend a trans shield or blanket for a small block 727? Be nice to hear some reviews before I purchase one.
Thanks
Link to your product?Where were you people when I produced the BEST blanket on the market. For Mopar only, 727's & 904 and Push Button Cable Shift !!!! it fit's like a new suit. It also coverd the bell housing. No problem with tranny dip stick. No more capturing shift lever arm. It has cooling ducts to prevent heat build up. No more ugly belts hanging out the bottom. I also exceeded the SFI requirements with flying colors in the ballistics test.
Thickness has no bearing on strength!!!!!
Did you know you only have to pass 50% the SFI test to be certified???? Think hard about that one.
Go to you tube: Performance TV episode 1806 to see what you missed.
That is exactly what I ran into, didn't see any other way around it. I'm not unhappy with the shield thought.Well, I guess I will have to buy a shield since there is no room between headers and shifter bracket to fit a blanket.
What shield did you go with?That is exactly what I ran into, didn't see any other way around it. I'm not unhappy with the shield thought.
I have had to cut off a few of the unused bosses on the case of my 904s for the CSR shield to fit properlyI went with the CSR shield. I had to beat the seam flat and beat the whole passenger side of the tunnel larger.
I had an empty case I was able to use for mockup and that paid off big time.
Heating issues were solved by using simple heat shielding wrap around the headers. Soft blankets can be easily cleaned of oil saturation. If your leaking that bad you should fix your leaks! You are a hazard to the other racers on the track. Blankets returned to me that were not abused were RE-certified (as per SFI) for another 2 years. I did this "free" of cost except fot shipping charges (less then $20). No bosses need to be removed to make it fit. It fits in "ALL" trans tunnels without modification.
Now a few words of caution. After market drums do not always help. In fact they can make things worse! All they do is increase the rpm at witch they will explode. And when they do release at a much higher rpm they can release even more explosive energy. The drum explosion problem is not caused by the drum it's self. It is due to the failure of the over run clutch or sprag as some call it. Stock drums do not cause explosions. Stock drums do not cause the clutches to slip. Worn out clutch plates and friction disks do. Stronger sprags are available and can help.
However, the most common cause of the over run clutch failure is operator error.
What is the reason they fail? Engine blow ups. Other drive line failures like drive shaft breakage and rear end breakage. Operator failure? Yes! When you leave the starting line and the tires slip "NEVER" let off the throttle and slam it back down. When you let off the gas it unloads the over run clutch. Then when you slam the gas this reloads the clutch with a sledge hammer effect. This slams the over run clutch into engagement. You all know what a neutral drop is right? This causes the over run clutch to break.
So here is the real skinny on protection. Use the lightest aluminum drum you can get. They will release (blow up) with less energy since they have less mass. I have researched this intensely from racers personally. Steel drums will more than likely destroy the carbon fiber shield and injure is likely to occur. Aluminum drums may give you a chance since they are lighter, thus having less kinetic energy.
One thing you people don't realize is that ballistic materials of high quality that can do this job are very expensive!! Imagine trying to kill a cow with a BB gun. A police vest is over $1200. The cost of my blanket at $800 is a lot less than loosing an arm or leg or some life changing injury.
That would be great !! I m sure there is a market for them including meWhen I spoke with Rick Allison at the Mopar Nats, it was my understanding that he still has intentions on producing an aftermarket case for the 727/904. When? That is to be determined.
Yes sir, as for me and many others as well.That would be great !! I m sure there is a market for them including me
