Transaxle
mecanovi
Active Member
woippy
Bonsoir,
Sur la boite de vitesse manuelle 3 rapports de la Valiant , a froid je trouve que la 2ème accroche au passage et au rétrogradage (levier de vitesse au volant).
Est-ce que ça pourrait venir du froid exterieur -2° ou de la mauvaise huile dans la boite ?
Quelle huile faut-il mettre dans la boite ?
What oil transaxle manuel 3 speed for valiant 1964 ?
It's not a transaxle (you find transaxles under front wheel drive cars, think Honda civic or Mini Cooper for example). It's a transmission and it uses 80-90 (same stuff you use in your rear end.
Also he was typing in French (I have no idea what it says, I don't speak French).
J'regret mon ami, non parlez Français.
According to the 1972 Owners Manual, Chrysler recommended Dexron for the manual transmissions for cold climates. In warmer climates, they suggest SAE 90 for the 3 speed and SAE 140 for the 4 speed.
The distinction between transaxle and transmission made earlier is correct. In France, think Peugeot 404/504/604, each used a transmission, Renault 4/5 (LeCar in US), 9/11/21 (AMC Encore, AMC Acclaim, Eagle Medallion) used a transaxle.
