transmission blankets
crazy 340
quebec canada
maybe going with a transbrake this spring so i need a blankets
which are the good one and easy to install
still have the OE floor so no place for a shield
will it get my trans hot on the street???
I use a blanket. They are fairly easy to install. I would recommend using a good trans cooler.
I have ran a trans blanket on the street for years and have never had a problem. As previously stated I have a MASSIVE trans cooler plumbed with 6AN line. Hope this helps, Eric L
thanks for the reply
I knew I hade to have a big cooler thats why I already have one
for the line what I have for the moment is 5/16 hard line
but will go to an6 as soon the spring come
to cold -28*c last week and -23*c today :wack:
You can buy a nice CSR carbin fiber shield that will fit the OEM floor why chance burning up a trans , when I got my car it came with a trans blanket but the car was only used at the strip when I put it on the street the first thing I took off was the blanket and replaced it with the CSR
