S soaringcowman Well-Known Member Joined Jul 9, 2007 Messages 151 Reaction score 0 Sep 20, 2009 #1 what size AN fitting is the transmission cooler fittings on the transmission? I know the hose is 6AN. adam
Duster346 Chris Andrews Joined Nov 13, 2004 Messages 555 Reaction score 339 Location Castle Rock, CO Sep 20, 2009 #2 1/8" pipe thread (NPT).
H hydro Active Member Joined Jan 17, 2007 Messages 39 Reaction score 8 Sep 20, 2009 #3 The case threads are 1/8 NPT but the tube is 5/16" O.D. which would make it a 5 AN size. Good luck finding that one. If you can find a 6 AN fitting with 1/8" NPT threads that would work to adapt a larger tube.
S soaringcowman Well-Known Member Joined Jul 9, 2007 Messages 151 Reaction score 0 Sep 20, 2009 #4 thanks for the info ;). i think i'll get a 1/8 npt to 6AN. and then get a hose end thats a 45 degree 6AN to 6AN.
