yellow rose
Overnight Sensation
That is somewhat true, but it is less frequent than most people believe. The bottom of the radiator is the coolest part. With a 180* thermostat and a 10* temp drop, it's 170 around the cooler. The temperature of the transmission fluid entering the cooler is higher that that.
And the ambient temperature is never over 110 unless you are in the desert.
