Transmission crossmembers
Gag_Halfront
I'm putting the 727 from my Fury into my dart. The dart currently has NO trans cross member. I found one for a '73, but will it work on my '71? Is there a difference? I know that the mount itself changed, but if I have a 73 mount and a 73 crossmember, can I fit it into my '71? If they are different, can anybody post pics of a '71 crossmember?
Thanks so much in advance for any guidance.
Yes it will fit.
73+ spool mount
67-72 Biscuit style
Thanks, Crackedback. I just wanted to make sure that A) none of the random bits of scrap I have laying around were a pre-73 crossmember in disguise and B) the bolt holes were spaced the same and the mount would be in the right place. I appreciate the quick response.
