ElephantKiller
I know it's not an A body, and I know it's not a classic, but I know there are a few of you guys out there that work in dealerships and know your stuff. I have a 2002 Dodge Stratus ES Coupe with the 3.0 V6. I'm wanting to flush the transmission and need to know what fluid to use. The manual says Diamond SPII or SPIII, I've always been told that everything after '01 needs ATF+4. Which should I use? I would like to use the ATF+4 because it is easier to get (no Mitsubishi dealerships close), but I don't want to create problems.
