CudaTime49
Active Member
Need help identifying my transmission. It is attached to a 1968 340 Formula S. I do not have a fender tag or buildsheet for this car. I'm not sure if the engine and trans are original, but I have the engine disassembled and it has been rebuilt.
There are no casting or stamping marks on the flared end but there is a number that looks like it was welded on "260-4". These numbers are about 2 inches high and look like they are made from wire and soldered on the case (See pic). There is a cast KCP 230-260-4 on the center case and the number 2466901 on the tail. Any ideas or leads would really be helpful.
