I crank em down so hard it almost strips the threads.
One of the best you can get.This is the gasket I installed today. The first time it had whatever came in the kit. I think it may have been neoprene
Yet it still leaks. Just my luckOne of the best you can get.
It's not the gasket. It's the installer.Yet it still leaks. Just my luck
Fair enough! HahaIt's not the gasket. It's the installer.
lol
I've never used this gasket ! Looks very well made though ! I have used the other gasket that OP used ! I've had good luck with those myself !! Think I'll get me that Moroso gasket for mine !I'm like you. A leaking pan gasket is something I've not had issue with. I like these though. Last pan gasket you'll ever buy. Well worth the money.
Moroso 93110 Moroso Transmission Pan Gaskets | Summit Racing
Im gonna try it again with the tips given here if it still leaks im gonna get a new pan if it leaks ill rtv and weld the damn thing in hahaI've never used this gasket ! Looks very well made though ! I have used the other gasket that OP used ! I've had good luck with those myself !! Think I'll get me that Moroso gasket for mine !
Just fair warning. Sometimes you need longer bolts. That's a small inconvenience though. Wait till you have one in your hand. They're badass.I've never used this gasket ! Looks very well made though ! I have used the other gasket that OP used ! I've had good luck with those myself !! Think I'll get me that Moroso gasket for mine !
I use these two torque wrench’s for all my transmission work ! I bought these years ago ! Probably one of the best investments I’ve made !!Yes I thought of that I went thru a couple different time and retorqued them my torque wrench sucks and I need a new one but I most definitely got a click its possible its too much 12 lbs isn't alot thats for sure
Never seen em like that before very coolI use these two torque wrench’s for all my transmission work ! I bought these years ago ! Probably one of the best investments I’ve made !! View attachment 1715801646
BUy a cast aluminum pan. They have a super thick machined pan rail.I have a steady drip on my trans pan I just dropped and replaced the gasket and filter. I used a lube locker gasket no cheap one and its still leaking. I drove the car around today to heat it up let it cool drove it some more let it cool still leaking. What gives? Do I need to use rtv? I tighten the bolts to 12.5 lbs or 150 inch which is what i read it called for.
I use one of those to set pinion drag on rear ends.I use these two torque wrench’s for all my transmission work ! I bought these years ago ! Probably one of the best investments I’ve made !! View attachment 1715801646
Hard to argue against that. They are nice.BUy a cast aluminum pan. They have a super thick machined pan rail.
It will not leak no matter the gasket. I don't used stamped metal pans for anything anymore. Differential, valve covers and trans pan
are all cast and never leak.
I had considered them till I saw the price of them. I was trying to avoid spending that but I may cave and just buy one.BUy a cast aluminum pan. They have a super thick machined pan rail.
