[SOLD] Trick Flow 240's,Hughes Rockers and Trend Pushrods
Fast01
Farmingville, N.Y.
Being a hoarder of parts and having the inability to move in one direction, I reluctantly have up for sale a pair of new, never run Trick Flow 240's, Hughes 1.5 rockers and Trend pushrods. Everything has been bolted to a block, torqued down and mocked up, but never run. I change directions like most people change underwear and I've come to the conclusion that I can't keep everything. Especially, since my second motor has basically been sold.
Anyway, the Trick Flows came set up for a solid flat tappet (1.550" diameter, 138#@1.950" and 430#@ 1.250", .680" max lift) or hydraulic roller, but I swapped springs and retainers to run a solid roller. The springs on the heads now are PBM's, 1.550" diameter, installed at 1.950" with 220 lbs on the seat and 580 lbs at 1.230". Max lift is .720". They have titanium retainers and 10 degree locks. The rockers are 1.5:1 with the billet steel hold down kit. The Trick Flows use a different width hold down than factory heads or even Edelbrocks. I have both included. I wrote "TF" in sharpie on the Trick Flow pieces. The pushrods are brand new, custom pieces from Trend. They are correct for theses heads with a solid roller using Comp lifters on a low deck block that has been decked. IIRC, mine has had .030" taken off. I will include the original springs that came on the heads with the chromoly retainers and locks. These are quality pieces. Trick Flow didn't use junk! There's over $3,200 in parts here not counting the extra set of springs and retainers....I'm pretty firm at $2,700 for the lot, plus shipping.
Tried to pm you, but you're box is full. What we're you thinking? I'd consider trades if it furthers my build.
Heads and hold-downs are sold. Rockers and pushrods still available. I will post a new add when time permits.
