Scody21
Just send it
What else was changed when the exhaust went in? Are the plug wires in the correct spot? 18436572... and pressed firmly on... how fresh are the plugs?
I have shorty headers. I set the idle mixture screw 1 1/2 turns out from tight and then adjusted it with a vacuum gauge to get as much vacuum as possible. Plugs are new, but have a lot of carbon on them when examined.If your car has hydros, you should be able to crank adjuster to zero (finger tight on the pushrod) then turn it even more and the valve will not move as there is .060 preload minimum on those hydros with no oil pressure. Solids will move once snugged. Check TDC on balancer to #1 rotor phasin and plug wire order. Simple to swap a pair of wires when your rigging it up or just drop the drive in 1 tooth off. Even some solids will have a snap ring so thats not 100% unless you see no snap ring at all, thats a solid lifter for sure.
Well now, we got more info. If it idles poorly in gear, your mix is off. If you installed headers, its gonna lean it out, if you went back to manifolds your probably fat. IF you got an exhaust leak (318 manifolds on a 340 head) its gonna run like crap and sound terrible. Same as a vacuum leak, may run but youll be chasing the idle. Start spraying the manifold gaskets and carb with water from a spray bottle and listen for the idle to change.
I can post pics/video tomorrow.Ok, good. We have a student with some actual sense. That's good. Most people don't even know what the mixture screws are. I think we can actually help you. Do you have any way to post a video of the car running.....if it will run? I don't care how crappy. If we can hear it run, that will help. It sounds like a low compression engine someone put too large of a cam in. Don't fret. If it is, it can be made to run.
Check your plug wires a third time. If you could adjust idle for highest vacuum at 15, thats not too bad with a cam. Stocker will give you closer to 20. Tough to nail down. Clean plugs, test wires on ohm meter. Spray the carb with cleaner around the bleeds.
I agree with this except using carburetor cleaner to test for vacuum leaks. Please use water in a squirt bottle. You don't want to literally throw gas on a fire.
What carb?
Your no fun... . Maybe some of us like walking on the wild side...
Yeah...my post #24 said use water spray on intake for vacuum leaks...use carb cleaner in the carb throat.I agree with this except using carburetor cleaner to test for vacuum leaks. Please use water in a squirt bottle. You don't want to literally throw gas on a fire.
