7
71Twister1owner
Guest
I've attached two close ups that might show the clip better. I let Friday get past me (at work) without getting to call the company that was recommended. I loosened a clip and there is no slop to move clip around. Best I can do is to bend clips if I figure out the desired "tilt". I may not be able to remove and replace some of the screws - some seem to be blocked more than others by the gasket.
Original message.
My 71 Duster was just repainted and clips around windshield were replaced with what appeared to be the same as the original clips. The trim doesn't want to snap into place. A local windshield shop looked and said that, possibly, the screw heads were too big. I would have to do some homework to find where I bought the new clips.
I was wondering if anyone has had a similar problem and can recommend a solution. I have a bad feeling that I'm going to have to have the windshield pulled and a different set of clips installed.
Original message.
