Trunk Lid gasket- 66 cuda
Viper21700
Aiken SC
Ok gents, just a little FYI, Advance has some D shaped gasket material in stock usually. Comes on 8ft rolls. Granted, its not the original shape, but I discovered today it works great to replace the trunk lid seals on our old cuda.. takes 2 rolls (12 ft total... actually take 1 1/4 rolls). The yellow gorilla snot weatherstrip adhesive works great to attach it with. my old seal leaked like a screen door, so I picked a roll up tonight to check it.. Works good, and actually looks pretty danged good... But I will say, its a TIGHT fit when you close the trunk lol. Its going to take a while for the sun/heat to make it a bit easier to shut the trunk. Ill post some pictures tomorrow after I finish up putting the rest in. I put my seams on the bottom of the trunk btw.. I water hose tested it for a bit and then hit it with a 10 gallon bucket of water, no more leaks.
Now I need to find some replacement door weatherstripping to replace the rotten door seals... Oh well....
