Need some help finding advise on mounting my battery in the trunk. Is there specific info. on where I need to run the leads and cables. Interior or exterior etc.... Thanks in advance.
i have mine in the trunk,it's in a moroso batt box negative cable goes to a bolt going through the framerail.wire wheel it for contact,positive cable ihave running under the car to the starter.use a short cable from the relay to the starter.....Need some help finding advise on mounting my battery in the trunk. Is there specific info. on where I need to run the leads and cables. Interior or exterior etc.... Thanks in advance.
